216
11
Does anyone know about changing the guts in these? Way back there was a thread about it, but... Recommend a suppler ?
Never did a Ryobi, but I have rebuilt a few DeWalt and Milwaukee packs over the years. Digikey carries a good line of NiCd and NiMH cells (including the high capacity ones for power tool applications), with solder tabs prewelded onto the ends. If you give them a sketch of how you want them assembled, they will even solder and shrinkwrap them into custom assemblies for you. http://www.digikey.com
Posts: 943 Likes: 2
Check out the cost for new ones before rebuilding old ones, Ryobi prices were a lot lower then other makes, it might not be worth it.
Posts: 869 Likes: 4
Have you taken them apart already ? I have seen the odd Ryobi batterypack where the spotwelded tabs have come loose. Resoldering it will solve the problem.
Generally I prefer Makita but i fix the odd faulty battery pack for a friend of mine.
Most often they are sub C and are available from any good electronics hardware store.
Check prices per cell first, quite often if more than one cells are faulty it is better to replace the lot. It is not real good practise to fit one new cell in series with older cells which are already on the way out.
I just bought a two pack of the 18v(called One+) packs for my Homelite lawn tools, which were Ryobi packs, for $35 at the orange place.
Look for a store calle Batteries Plus. They rebuild battery packs for a very reasonable cost per cell.
The Ryobi "ONE+" range is where you buy a bare tool and the battery/charger separately. At $35 a pair it's not going to be worth rebuilding, so long as the contact end is compatible with the older tools. PS: They're $54 each here, you lucky persons!
