163
I now have a small tool allowance....$150.... from the company, and I am thinking of buying my own new meter for the first time in about 30 years
I have no pre-disposition for any particular brand, however the allowance can only be used with a vendor.
my apologies to the ECN webstore.
...I cannot buy something and be re-imbursed...... and any thing over the allowance will be cheerfully deducted from my pay .......all at once
so, the only choices available are ..... in no particular order..... Greenlee. Fluke Ideal, Amprobe
any one have a preference i'm open to suggestions
I like my fluke 110 it is right in your range I think.
Go for the Fluke. Awesome meter.
ECN should be a legit vendor, talk to your boss. You'll get a reciept, that should be all they are worried about.
Even if you go over the $150 allotment, save your reciept. Chances are that you can deduct anything over the $150, off your personal taxes at the end of the year. So don't skimp out, get what you need and get something good.
Posts: 794 Likes: 3
Be aware that some digital meters are slow to measure hundreds of volts AC. Like several seconds. You could see "120" as it works its way to "277". And you don't have to be a rocket scientist to know what would happen if you confuse 120V wires with 277V....
Dnk, I should have been more specific....I can only use the companys' suppliers...which limits me to three houses
Kirby-Risk .......elec All-Phase,......elec and Fastenal.....whatever
.......I cannot buy what I want and merely turn the receipt in.....
togol, get them to set up an account at ECN then.
I'm sure Bill wouldn't mind.
Posts: 827 Likes: 1
Togol, it's hard to suggest, not knowing what you already have access to. If you already have a clamp-on ammeter, that Fluke 110 looks like a good choice. But if you don't have a clamp-on, consider one that also comes with test leads for other DMM functions. The 110 max is 10A AC or DC. I take a Fluke 187 into the field but I can always bum an Amprobe if I need one. Joe
Posts: 869 Likes: 4
Get a Fluke.
They are very reliable good quality meters.
As we used to say after a coworker went to work in the engineering department at Fluke, "If it works, it's a Fluke."
