1 members (Scott35), 161 guests, and 23 robots.
walrus Offline OP
You know what else is weird, your basic gas station hose has a static wire built in, you have continuity from one end to the other. Airplane fuel hose doesn't (in most cases) from the engineer tells me. Touching the nozzle to the wing won't do diddly squat.
LK Offline
"The owner has been talking to an engineer who has helped set this system up."
There seems to be your first problem, tell the owner, you need a sealed and signed set of prints from the talking engineer, talk is cheap, the owner has to pay for the design, i would not touch that job without a sealed print.
I flew into both first class airports, and grass strips, that you could not find on a map, some have the best fuel equipment and services, and some have nothing but a drum and hand pump, when your dealing with fuel, safety is first.
"engineer who has helped set this system up."
Helped or is his seal on the job? , does your insurance have E&O coverages for design work?
[This message has been edited by LK (edited 08-19-2006).]
Walrus: Touching the nozzle to the wing won't do diddly squat.
If what they tell you is true, touching the nozzle to the skin first would be even more important.
Joe
walrus Offline OP
No prints, no seal, thats why I'm trying to get this worked out.
I checked the hose for a static strap, no continuity from one end to the other.
