Electricians revenge
1 members (Scott35), 184 guests, and 13 robots.
Page 3 of 3 1 2 3
K
Someone I worked for YEARS ago ..used romex connectors as a VERY temp thing .. till we could get back the next day with the proper split bolts.. not pretty .. but it worked
3 split bolts, little cambric, little rubber tape, little "Super 88", and all is good [Linked Image]
I've used polaris taps (or insultaps) before.. I just add the cost onto the customers bill and leave em.. The poco usually ends up leaving them vs. pulling the ladder out. [Linked Image]
LK Offline
"I just add the cost onto the customers bill and leave em.."
Now, that's a new concept !
V
Question, I use split bolts (bugs,Kearney,whichever you prefer) or set screw barrel splices and tape. Often the POCO does not replace the splice ever. Do you think if some one used a romex conn. that the replacement rate would be higher? Just curious. Rod
Venture:
Guess it depends on the utility co. Here in NJ a 'cut-in-card' is sent to the POCO upon inspection, and they show up (at their will) to make perm conn, replace drop (if req) and install meter/new meter & seal meter cab.
2x4's
Now that's overkill!
I once saw a temp service for an Austrian fair... they tied a 1x2 to the metal restroom trailer using conduit wire, ran two screws into the end, laid the quadruplex cable between the two screws that stuck up like a fork. They then erected their work by climbing up a ladder one of the helpers was holding in mid air...
Page 3 of 3 1 2 3
