231
11
My suppliers don't stock them. The state electrical inspector didn't know anything about them until he talked to the head guy.Are you guys using them?? does a 2" connector cost you 36.oo dollars like it will me if I order them Should I just use PVC .
How many connectors are you going to be getting for $36.00? They are sold in boxes that have more than one inside them.
Probably going to get a bunch of arguments here, but I dont like EMT in wet locations. You end up with a bad batch of conduit, and it starts rusting on you etc, things look like crap soon after you are done. I prefer PVC, and with the price of metals these day,it may work out cheaper, even with the bonding conductor, and some specs call for bonding conductor even with EMT.
Posts: 7,382 Likes: 7
Walrus: You must mean "raintite", like we call them down here (NJ). Honestly, I don't have a clue on 2" cost.
Keep in mind that most 'raintite' emt conn/cplg lost the UL approval a while back. The small sizes 1/2 to 1-1/4 are now approved, but look out for old stock.
I would do PVC. Even with expansion joints (if needed) & grd. conductor it should work out cheaper.
Posts: 9,931 Likes: 34
I like PVC but it alawys seems to droop in the sun. Wnen I did my screen cage I used EMT so it would look better but I did paint it before and after I put it up. Between that and the galvanizing it seems OK.
I have to run 30 ft done the outside of a building with 2" and 1 1/4". PVC will look like crap in a year although its on the back side of building and shaded by trees. The price of 36 dollars is for 1- 2" conn, made by Steel city.
Walrus: From Catalog 396, WW Grainger Die Cast 2" Raco 2838 @ $9.48 (Insul) Steel 2" Raco 2918 @ $26.20 (Insul) Die Cast 2" Raco 2808 @ $5.98 Steel 2" Raco 2908 @ $20.15
Cplg is Raco Zink 2828 @ $ 6.09 Steel is 2928 @ $ 19.87
As usual, catalog prices are subject to change, this is '05-'06 cat, you have a branch in Portland.
Hotline, thanks, the ones I was quoted must be steel but diecast would be fine for my application. I'm in the midle of a peeing contest with my biggest supplier and one can see why.
Walrus, Gilman's or horizon?
