0 members (), 483 guests, and 9 robots.
#67159 06/27/06 10:11 PM
derater Offline OP
Ah hem, gulp; well someone didn't tape over his 3" 90 UG service pvc and I'd bet I'll find it full of water tomorrow. Looking for tips on getting it out. I may have to fire myself . Thanks
#67160 06/27/06 10:22 PM
F
There is few tricks you can try get most of the water out of the conduct
1} use shop vaccum to suck much water as possible
2} use the compressed air to blow the water out [ make sure no one is standing on the oppstite end other wise will get soaked from " fontaion " or shower ]
but dont expect to get all of the water out of the conduct 100 percent of it espcally if run in UG set up
Merci , Marc
#67161 06/28/06 12:06 AM
Use shop vac and a conduit mouse, should do a reasonable job.
#67162 06/28/06 05:08 PM
...it's that the reason we use conductors with a "W" pre/suf fix in the them [Linked Image]
~~ CELTIC ~~
...-= NJ =-...
