515
15
I think that this topic was mentioned before but I just ran across this. I am till not sure if I like these or not. http://www.gizmag.com/go/5287/ What do you guys think?
Seems like a good idea but would like to see the backside of the device before I would use them.
Kinda makes the ground up/ground down argument a mute point, though [This message has been edited by IanR (edited 06-19-2006).]
Well the article says it's "Backwired". Hmmm......I'd have to take a look at one in real life. I'm not to thrilled about it being a "residential grade" socket. That's just another name for Grade-F cheap-dung stuff. Look at those 50 cent light-sockets sold at Home Depot. After a few months of heavy use, they're worn out.
I'm kinda disturbed by the statement "for the novice do-it-yourselfer, the callouts for hot, neutral and ground are clearly marked on the back (paraphrased)". That, plus I'm a little dubious of how the receptacle can carry a full 15a.
It'd seem to me that the contacts would get pretty worn down after a decade or so, meaning that if it were actually used for anything near a full 15 amps it might go up in smoke. I'd like to crack one open and see how it works. -Will
Posts: 869 Likes: 4
I have my doubts about the durabilty of those powerpoints. I like to see what type of sliding contacts are used within them, or they just twist the supply cable behind them ?
It's more a sales tactic to make these ppt's look very practical, but I reckon that these ppt's will cause fires or poor contacts, when loaded near their maximum rating for a period of time. You'll be replacing these every couple of years is my guess.
Here's a link to the website: http://www.360electrical.com/ I see on there that the device is of UL-Compliant Design, whatever the heck that means. Count me in with the others concerned about long term heavy current use with questionable connections. Radar
That means that they resemble receptacles that are UL compliant.
Yeah, they have holes that plugs fit into.
Their address is in Salt Lake City, UT. Maybe we should send Ryan J over there to get us a sample
