#66751 06/16/06 05:41 PM
GA76JW Offline OP
I just saw this video on Break.com and it is kinda funny. Heck of a way to lose the plane though.
http://www.break.com/index/rcplanecrash.html
#66752 06/16/06 05:59 PM
What does that do to the integrety of the wires? I am imagining some burned notches briging the wire size down a few.
#66753 06/16/06 07:46 PM
e57 Offline
So I watched that sever times, and I believe (its hazy) one phase falls with part of the plane, but at contact you can see the conductor recoil, after that the image is even poorer.
So, do you think that it may have been done on purpose? I do....
#66754 06/16/06 08:24 PM
I'm sure it was an accident- it's very difficult to guage depth perception when flying a plane at any distance; he probably thought his plane was well on this side of the wires.
On a related note, I've got a little R/C plane I fly all the time in this tiny little park beside by house that not only is too narrow and too short to really be flying a plane in, but ALSO has high voltage lines running about 50' up! Needless to say, I have an interesting time- I can't tell you how many times I've bounced off those lines. (The two planes I fly there only have 2' foam wings and are way too small to short the phases.) The lines dent the styrofoam when it impacts, though. Usually, it recovers before it hits the ground, but is porpoising so badly I have to land anyhow.
Edit: he probably had metal aileron pushrods in that- I can't see balsa or foam alone being a good enough conductor to explode like that!
[This message has been edited by SteveFehr (edited 06-16-2006).]
#66755 06/17/06 04:42 AM
Is it a jet-engined model? True miniature gas-turbine jet engines are now available to modellers, albeit at a price. http://www.airtoi.com/jets.htm
