Yeah!!!
Nice catch!
Probably more glitches if you look hard enough.
We can spread the word that if they don't change that then all tests based on the 2002 would be invalid.
All new projects are under the 2002 NEC (CEC). So only electricians working on legacy projects (permitted under 1999 NEC) are covered by the law.
Wait, even better. The state does not adopt the NEC at all. It adopts the CEC. So technically, there is no one in CA installing per the NEC. Whether it be the 1999 or any other edition.
