I'm curious as to what kind of terminal connections that little switch has.
Here's a closer look, one terminal with a conductor in place:
Looking through the brass collar from the rear:
These tumbler switches were generally mounted on a wooden block, the latter having holes drilled to match the terminal locations so that the wires could pass through.
