1 members (Scott35), 381 guests, and 13 robots.
#65268 04/30/06 10:01 AM
K
kg18 Offline OP
We just found out that the lights on the sport court we were supposed to wire are going to be 240v. What is the best way to switch these lights. We plan on locating the switch on the house next to the sub panel not on the light pole. Thanks
#65269 04/30/06 10:57 AM
How many lights? I'd use a contactor(s)
#65270 04/30/06 11:06 AM
What is the total load and / or number of circuits?
Roger
#65271 04/30/06 12:34 PM
I like the time clock and/or contactor combination [Linked Image]
~~ CELTIC ~~
...-= NJ =-...
#65272 04/30/06 01:14 PM
K
kg18 Offline OP
1 circuit to each light. I am not sure on the wattage, but I am sure they are pretty hefty. Thanks for the input guys.
#65273 04/30/06 11:05 PM
I imagine a lot of lights...with a LOT of current inrush at start-up.
I suppose, in a perfect world, there would be some sort of contactor that would turn them on in sequence, with a couple of seconds between wach on- spreading that inrush over time.
Has anyone ever seen such a product?
#65274 05/01/06 12:40 AM
Potter Brumfield makes adjustible time delay contactors but I bet they are pricy.
There are lots of ways to do it electronically but that is probably not "listed"
[This message has been edited by gfretwell (edited 05-01-2006).]
#65275 05/01/06 05:25 AM
A standard lighting controller could be programed for sequential operation.
I would not worry about inrush currents unless we had 100's of fixtures.
We do a lot of site lighting and switching on 100 to 200 - 1000 watt MH fixtures in one shot is common with no problems. Usually an entire panel(s) is contactor controlled.
However I do not think we are talking about a stadium here, just a house with a court.
As he mentioned the switch beside the panel why not just get SWD rated breakers?
Beyond that a simple multi-pole contactor would be a simple way to go.
#65276 05/03/06 12:39 AM
kg18;
What does your Client want to do, as far as the way the Lights are controlled?
Ask the Person(s) with the responsibility and Authority to make these decisions (like who signs the check, wanted the lights, etc.), what controlling methods are wanted for these lights, and quote prices accordingly.
There's about 10 "Best" methods I can think of right away, for controlling these Lights, ranging from a "Simple" approach using a 2 Pole Spring Wound Timeswitch per each 2 wire circuit, upto "Detailed" approach, involving time clock / photocell / over ride timeswitch driving a Lighting Contactor.
One major Question:
Does your State / County / City require Energy Conservation Compliance?
If yes, then you will need to control the lighting per the Compliance Documents of that Commission.
Just my $0.02 [Linked Image]
Scott35
