381
13
I need to illuminate pictures on a shelf. The shelf is 78" wide and 24" from the ceiling. I would like to use 4" LV lights and an eyeball trim. I don't know how to figure out how far away from the wall I should place the cans and how many cans I'll need.
Any help would be appreciated.
Frank
A decent lighting supply house can answer that, or try the manufacturer.
You can also do a mock-up of sorts by buying one can & trim, and get something to serve as a shelf of about the same depth, perch the 'shelf' on something (boxes?)against the wall a couple of feet above the floor, hold the can light a couple of feet above that and move it back and forth to see what distance makes the best overall light coverage at the 'shelf'. A little trial & error without any damage and little cost.
Radar
You may find the max angle of the trim in the catolog. Mark on the wall where you want to be then use an angle finder gage to help pick can location. I would not figure on the max angle side so you have some adjustment.
Frank,
I've found that the top of my circle or oval that the light projects on the wall is real close to 1" down for every 1" away from the wall. So figure out how high you want the top of the beam and move off the wall the same distance.
Posts: 7,381 Likes: 7
Frank: First, let me welcome another 'Jersey Guy' to the ECN forums. I'm close by to you & my e-mail is in my profile.
Mfg catalogs (cut sheets) or specs can give you the info you need. I'm assuming you are going to a supply house, not the 'big-box'??
Remember, if you are talking MR16/MR11 the actual beam spread of the bulbs is important. Also, did you think of the adjustable 'gimbal ring' type recess??
