what type of cable is that
We also have this product available in copper to, and its called teck cable. btw that is done exactly how we have to do it in British Columbia. and thats is a 2 1/2" rigid riser (Called a Mast) here and can be 50 inches before it needs guying here.Those ubolts will have a back plate and lock washers and nuts drilled into blocking that would of been added. we have to remove the wall board to install the blocking.
