#63752 03/25/06 09:49 AM
GTE Offline OP
Can a residential recess light marked for use in wet locations, be used used in a shower without being marked for shower use?
What makes the difference?
#63753 03/25/06 12:40 PM
Tom Offline
If the fixture is marked for wet locations, then it would be appropriate for installation in a shower. See 410.4(D)
#63754 03/25/06 03:25 PM
You MUST use a rated shower trim by the same manufacturer, too.
Stupid should be painful.
