519
18
I was wondering if by chance someone knows where I can get my hands on a 4 gang weather proof gfi cover. I have tried looking everywhere and you guys are my last hope. Thanks for any help.
I don't think I've ever even seen one of those.
It looks like a 3 gang is the most. What is the situation?
The guys cut a 4 gang switch bank in outside the house for some trellis and pool lighting. Now its time to trim it and we can't find a four gang cover. I really wish they had cut in 2 2 gangs. I inherited this little mess. everything i have seen has all been 3 gang max. I just thought somebody might know of someone who has them.
I guess I could just weld 2 2 gangs together :-)
i never see a 4 gang weatherproof box cover at all i did check few sources and no one ever make like that unless it is requested a comstiom [ specal ] made which i belive the cost will be outragous if they do make it.
But honestally most biggest one i ran into is 3 gang verison the max but never the 4 at all
Merci, Marc
Posts: 7,382 Likes: 7
Scameron:
IF it is/can be made......
Mulberry Metal Products, Union, NJ 07083
You may be able to Google a web site.
I had a similar problem some time back; let me tell you what my solution was- it just might work for you!
I bought a "raintight" gutter. Inside I mounted a number of regular metal boxes, and mounted receptacles on them with 'industrial' covers. In the bottom of the gutter I made holes large enough for the plugs to enter, and lined them with snap-in bushings.
I'll see if I can get Bill to post a pic here.
"Mulberry Metal Products, Union, NJ 07083"I pass by there every day on my ride to and from work. www.mulberrymetal.com/ -------------- Whoa, look at this: The widest selection of covers in the industry – a variety of openings, through 4 gangs, many available nowhere else. http://www.mulberrymetal.com/wpcovers.htm [This message has been edited by ShockMe77 (edited 03-14-2006).]
Shockme: Thanks for the links.... Another 'Jersey Guy"????
Drop me an e-mail Edit : BTW They once made me a 16 gang Decora in brass!
[This message has been edited by HotLine1 (edited 03-15-2006).]
Thanks for the info everybody. I decided to go with the four gang wp switch cover as a compromise. Our purchasing guy wanted to know how I found it and I told him the ECN came through once again. Thanks a million
