daffy03221:
Welcome to ECN!
In this case, the 14/3 is most likely wired as Black = hot, white = neutral RED = "signal" (or "interconnect") which is a low-voltage link between units.
So this would not be the dreaded multi-wire application.
Thus no issue at all with the even more dreaded arc-faults.
