Topic Options
Rate This Topic
#62507 - 02/16/06 07:33 PM Does anyone have the multiplier table for bending conduit?
Clydesdale Offline
Is there anyone who has the multiplier table for bending conduit? I would like to print out and laminate a copy of it in a pocket size format so I can start carrying it with me every day.
Thanks
Top
#62508 - 02/16/06 07:59 PM Re: Does anyone have the multiplier table for bending conduit?
Active 1 Offline
Loc: Grayslake IL, USA
I had metal number stamps I stamped in the flat top part of my 1/2" bender.
5 5/8 deg = 10.207
11 1/4 deg = 5.126
15 deg = 3.864
22 1/2 deg = 2.613
30 deg = 2
37 1/2 deg = 1.643
45 deg = 1.414
60 deg = 1.555
I round to the 1st decimal place and I know the common ones but I wanted to check myself so I listed all from one chart.
Top
#62509 - 02/17/06 05:21 AM Re: Does anyone have the multiplier table for bending conduit?
Ralpha494 Offline
Loc: Pewaukee,WI,USA
There's a good article at www.electrician.com in Articles 1.
I would have done the link right to it but wanted you to check out the rest of the stuff.
Otherwise, just use the cosecant of the angle you want to bend.
Top
#62510 - 02/18/06 08:57 AM Re: Does anyone have the multiplier table for bending conduit?
GA76JW Offline
Loc: Suwanee, GA USA
E-mail me your address and I will send you some of the pocket-sized tables we use at work.
Philip
_________________________
Top
#62511 - 02/18/06 09:21 AM Re: Does anyone have the multiplier table for bending conduit?
Dave T Offline
Loc: Waukesha, WI, USA
Ralpha494,
Your link is from Gerald Newton's site. Did you know that he started his form up again after a bout with being SPAMed?
Mater of fact the very latest post of his was about conduit bending. I'm not a conduit guru that has the experience to answer his question but maybe one of you guys can.
The subject is:
"Opinion about the Benfield Conduit Bending Manual by Jack Benfield - Gerald Newton 23/PST Tuesday/January/24/06 (0)"
It's another good place to hang out. http://electrician2.com/elwwwboard/wwwboard.html
Dave
Top
#62512 - 02/18/06 10:54 AM Re: Does anyone have the multiplier table for bending conduit?
resqcapt19 Offline
Loc: IL
The multiplier is the cosecant of the angle. A lot of calculators don't have that function, but it is also equal to the inverse of the sine of the angle.
Don
Top
#62513 - 02/18/06 02:46 PM Re: Does anyone have the multiplier table for bending conduit?
russ m Offline
Loc: Burbank,IL,USA
The multiplier method, even if not perfect, is fine for small conduit or stuff thats hidden. You can usually get it close enough to make it work.
If you have to be acurate, the best way to bend offsets is to field bend it. Field bending is described in a some books. I have an Uglys book and it is described under "Chicago Type Bender Off-Sets" This method can be used for foot benders and hydraulic ones.
Top
#62514 - 02/18/06 03:07 PM Re: Does anyone have the multiplier table for bending conduit?
RobbieD Offline
Loc: Canada
Here is some info for Greenlee and Ideal Benders. Maybe you will be able to cut and paste and make up some pocket cards.
http://www.idealindustries.ca/pdf/bendguid.pdf
http://65.36.183.19/greenlee/im/IM1071REV04.pdf
Hope these help.
[This message has been edited by RobbieD (edited 02-18-2006).]
Top
SE cable question
2017 NEC and Related
2017 NEC
Now Available!
Shout Box
Who's Online
0 registered (), 91 Guests and 10 Spiders online.
SE cable question
Top Posters (30 Days)
Admin 47
HotLine1 43
gfretwell 19
Ruben Rocha 12
Trumpy 9
Newest Members
Scotto, Freecrowder, clee512, Jdscott2005, FAIZAN
ECN Electrical Forums - sponsored by Electrical Contractor Network - Electrical and Code Related Discussion for Electrical Contractors, Electricians, Inspectors, Instructors, Engineers and other related Professionals
