#62293 02/14/06 04:59 PM
mshaw Offline OP
What do you like to use to splice the service entrance cable to the utilities service when doing residential service changes. Here the utility company can take up to 3 weeks to change a service over but we can make the connections and they will reconnect them later when they descide to show up. Remember you are doing this hot.
#62294 02/14/06 05:15 PM
Split Bolts
Dave
#62295 02/14/06 05:21 PM
H-crimps....
Dnk..
#62296 02/14/06 05:54 PM
I have seen split bolts, set screw inline splices, crimps, insulated splice blocks, insulated terminal blocks and, ( are you ready for this one ) NM connectors, with or without tape.
Connectors are not returned or left at the job site so expense [ as always ] competes with safety.
Alan--
Alan--
#62297 02/14/06 06:39 PM
I like the Polaris insulated connectors for the hots. I think they are about $15 each. A split bolt for the ground. If I had a crimper that would be my 1st choice.
#62298 02/14/06 06:44 PM
Burndy Crimps!
I used to work for a guy who would have us use 3/4" romex connectors.
#62299 02/14/06 06:45 PM
You guys do this out of a bucket? Can't imagine doing it off a ladder.
#62300 02/14/06 07:15 PM
If I never get to reconnect a service drop, I won't regret it. Those of you who do it, what precautions do you take? Does anyone meg out your entrance conductors first? That probably sounds excessive, but the idea of a 10kA fault occuring a foot from my face while I'm twenty-five feet up a ladder, is enough to make me pause.
=John
#62301 02/14/06 07:45 PM
Walrus, we do it both ways. Off ladders, in a bucket, off the roof, the bucket is easiest...
John, we do a tap test. Tap the wires together before you hook them up....
Dnk...
[This message has been edited by Dnkldorf (edited 02-14-2006).]
#62302 02/14/06 08:46 PM
Dnk, that's the "tapas turn" test right?
tap as you turn your head [Linked Image]
