504
20
Kindly help. How do these 3 wires match up to the standard black, white and ground? They came on a heavy duty wiring to an outside switch. Thanks
Blue = White
Brown = Black
Green Yellow = Green
At least that has been my experience with German cords.
Posts: 9,931 Likes: 34
400.22 Grounded-Conductor Identification(C) ... For jacketed cords furnished with appliances, one conductor having its insulation colored light blue, with the other conductors having their insulation of a readily distinguishable color other than white or gray.
At least that has been my experience with German cords. That's the standard for cords right across Europe, and in the U.K. and much of the rest of the world now as well. Brown = Phase/hot Blue = Neutral/grounded conductor Green/yellow = Earth/ground
I see blue and yellow 120v circuits in many non-permit pipe jobs. My guess is Europians doing the work and no one told them we use white and grey. No one told them you shouldn't put #14's on a 30a breaker.
We're in for a lot of confusion with the new adoption of European colors here as well. Just look at some of threads where we've discussed this in the non-U.S. area. No one told them you shouldn't put #14's on a 30a breaker. That's part of the hidden "in wall" electric heating system!
