1 members (Scott35), 526 guests, and 20 robots.
#61030 01/14/06 07:58 PM
grizzly Offline OP
I have an old Greenlee table saw that is used to cut aluminum up to one inch, as well as plastic and wood. It operates on three phase, 230 vac and is an old direct drive type. The problem is that it takes a very long time for the saw to coast to a stop. I would like to know if anyone has ever installed a dynamic brake on something like this before?
Regards
#61031 01/14/06 08:22 PM
We use a plugging contactor to stop coal shakers within 5 secs. Not the cheapest way as we have to change the contacts on the reverse contactor every 2 years at best. But they get used 500 times/ day, no BS.
We looked into softstart controllers but they didn't do what we wanted. Dynamic braking requires more room for all the associated equipment.
Hope this helps
Dave
#61032 01/18/06 02:55 AM
Grizzly,
Here's a Schematic regarding Dynamic Braking of an AC Induction Motor, which may be of some assitance to you:
Dynamic Braking of AC Induction Motor
The Schematic shows a 3 phase Motor, just edit to include 2 motor Leads rather than 3 Leads.
Also, you will need to have this braking system interlocked with some type of starter. This would be best done within a conveniently sized external cabinet, that contains all needed equipment.
Scott35
#61033 01/18/06 04:27 AM
Grizzly, if you fit a brake to this saw, don't use a dado head on it.
