1 members (Scott35), 104 guests, and 11 robots.
#59224 11/30/05 12:05 PM
I had wasps in the service mast. What can I use to seal off the openings where the wire enters? Caulk? If so, any particulare recommendations?
#59225 11/30/05 03:29 PM
Try Duct Seal.
#59226 11/30/05 03:35 PM
Fire foam works well, and it won't fall out as the weather changes.
#59227 11/30/05 08:16 PM
LK Offline
Steve,
Some of the fire foam products, becomes conductive when subject to moisture, i would be careful to check with the manufacture before using this for a seal, also the foam product may react with the insulation.
[This message has been edited by LK (edited 11-30-2005).]
#59228 11/30/05 08:49 PM
e57 Offline
ditto on duct seal putty.
#59229 11/30/05 08:54 PM
V
can you use the same clay stuff that is used to fill the connector in a meter socket?
Patrick
#59230 11/30/05 09:31 PM
That "clay stuff" is duct seal (also known as monkey-poo).
I use silicon caulking to fill the weatherhead.
Earl
#59231 11/30/05 10:15 PM
I'd also go with silicone
#59232 11/30/05 10:37 PM
I also think that Duct Seal would work fine. This reminds me of another sealer question... Why do they refer to the material that you pour into a seal off to harden as, "Chico"?
Joe
#59233 11/30/05 10:47 PM
A contraction of "Crouse-Hinds Co.", the original manufacturer.
