390
14
What is a ballpark price for a 400-amp service with the following: 2 - 40' 4/0 seu cables 1 - 320-amp meter socket 2 - 200-amp, 40 circuit, main breaker panels 1 - grounding system 8 - 2-pole breakers 40 - single pole breakers 1 - coordination with PECO 1 - Permit and Inspection I also need to hire a bucket truck with a operator/electrician from a local EC. This is a service change in the north east part of the US. I came up with about $5,200.00. Any thoughts?
Hank
I am sorry is that $5,200.00. the down payment?
That is the total price, another EC quoted the job for $3,200.00, but i don't think he looked at it.
Hank
Is this surface mount or semi flush? How far do you have to run your bonding to water, ufer, etc.? Do you need to install a riser or is this underground? Does the Poco supply the underground materials &/or labor or you?
Materialwise you seem to have around $1700-$2500 in parts. Decide how long it'll take you to do the install and then how much you feel your time is worth... As a licensed, insured, bonded, etc. EC I'd look at my time running around $130.00 at least. (So Calif gets around $275.0o/hr with the big name service co.'s)
Personally without looking at the job, but kind of picturing it from what you say so far I'd probably say around $7800-9000 if it was here in California... I know the economy varioes greatly across the country, so this might not work for your specific area.
Randy
The 200-amp panels will be surface mounted, the 2 - 4/0seu' will be strapped to the building, but it is 30' high, thats why I need the bucket truck. The cold water ground is about 50' away, that has to travel thru a finished (drywalled) part of the basement. I only need PECO for a new meter, but that has to be coordinated, which means time. This is a residential property.
Hank
For $5200 I'll hire you as a sub and make about $3K for myself!!
So your tellin g me you get $8,200.00 for something like that? I better start raising my prices.
Hank
why do you need a bucket truck if the POA is 30' high???? and ill rent you my bucket!!!!
HCE - One of the very important variables here is of course location. Yes, around the Boston area that sounds like a $8K job. (about)
I'm not going to strap down 2 - 200amp cables off a 32' ladder, It's easier for me to rent a bucket truck.
Hank
