Electricians revenge
0 members (), 205 guests, and 12 robots.
Page 3 of 3 1 2 3
When we were doing residential work we always installed a seperate ckt for the frig. We did large houses and many times HO's would buy large double door sub-zero monsters. Even when they didn't, we felt that was a good policy.
mbhydro is correct. In Canada, the fridge must be on a dedicated circuit...the only other thing you can add to it is a clock receptacle. Since 99.9% of clocks now are battery-operated quartz, clock receptacles are a thing of the past. However, I've installed clock receptacles in cabinet space for a microwave, so the unit can go back a bit further.
Sixer
The latest trend I see among the upscalers is to have two side by side sub zero refers in a kitchen. As far as load, those big built in types don't really draw much more than the regular ones, but the intallation booklets supplied with the unit usually request a dedicated 15 or 20 amp circuit.
3
My house has the fridge on the same circuit as the kitchen. It is RCD protected. My freezer is on the circuit for the two front bedrooms , lounge & laundry also RCD protected. My beer fridge is plugged into the 15 amp welder socket outside (RCD protected)
Page 3 of 3 1 2 3
