mbhydro is correct. In Canada, the fridge must be on a dedicated circuit...the only other thing you can add to it is a clock receptacle. Since 99.9% of clocks now are battery-operated quartz, clock receptacles are a thing of the past. However, I've installed clock receptacles in cabinet space for a microwave, so the unit can go back a bit further.
