... No, my helper got a little "ambitious" and went ahead and started the 1-1/2" run without me..he forgot the expansion coupling..he had it all glued together by the time I got to the site,I called the AHJ,and told him about it,and that it's only for Cable TV,and Telephone,and he said he wouldn't knock it down so long as the coupling was there for the 3" pipe.. I personally installed the one on the 3" pipe..I'm still stewing over redo-ing the 1-1/2" LB,anyway, and adding the expansion coupling there as well..I probably will,as there's no wire in the pipe ...yet..
Russ
