Here's how I wired my hot tub:
1) bought the tub
2) Opened a beer
3) watched electrician work :-)
Seriously, though....You want someone to use pipe, and not Romex, SE, etc.
You want a disconnect where you can find it.
If outside, you want the wires in pipe, buried DEEP.
You want everything GFI protected....well before it gets to the tub.
Finally, you want to keep ALL other electric stuff well away from the tub. Assume that everything you want to put within, say, 10 ft. of the tub is a bad idea, and don't do it. No paddle fan, no stereo, no yard lights, etc.
