by HotLine1 - 04/23/24 02:17 PM
0 members (), 231 guests, and 11 robots.
jkraft Offline OP
Anyone ever seen a battery charger for cordless tools that will take multiple brands. I'd like to charge my 18V DeWalt and 9V Makita in one charger at the same time.
Just go with separate brand specific chargers if you want both running at the same time...to charge two batteries you need two chargers.
However if you want a 'general purpose' battery charger, then you might want to look at the things used for RC racing. Many of these are microprocessor controlled, will quick charge quite nicely, can 'restore' overly discharged batteries, can measure capacity, etc.
I have had very good luck with the 'Triton' ( http://www2.towerhobbies.com/cgi-bin/wti0001p?&I=LXCJG7&P=FR ) charger; I use it to charge NiMH and Li-ION packs for hobby use, and have used it to 'save' Milwaukee batteries (I discovered that if the packs are left unused for an extended period, they self discharge, and then the Milwaukee charger doesn't 'see' the pack. By using the Triton to start the charge cycle, the Milwaukee charger would see the battery and everything worked fine.)
There are many other such chargers.
-Jon
Make one. Use the various tabs on the battery to close switches put in the a particular mode for that battery.
