#570 02/10/01 04:06 AM
I'm the kind of guy that could probably spend all day in a tool store. I'm always interested in hearing about great time-saving tools, especially the ones that don't cost alot. One of my favorites is a pen-shaped voltage proximity tester that has a tip that glows red and the tip (plastic) is shaped so it can be inserted into a receptacle slot. This is a HUGE timesaver. I don't know what I'd do without it.
Anyone else got something?
#571 02/10/01 07:07 AM
My volt-tic is #1 too... i've grown particularly fond of the phone like sound's ability to get people to answer a dead phone.
#572 02/10/01 09:13 AM
My favorite is the EMT reamer that slips over the shaft of a screwdriver and held in place by a set screw, it reams 1/2, 3/4, and 1 inch EMT. I love it.
#573 02/10/01 09:43 AM
Tom Offline
My cordless drill has got to be it for me. i use hex head screws with a nut driver bit, beats putting them in by hand. I've also figured out the correct clutch settings to tighten the wires on the switches & plugs I use. I also use the wirenut installer that comes in bulk packs of Buchannon wirenuts, you really appreciate this when doing connections that are overhead.
#574 02/10/01 09:49 AM
Tom,
If you can use your cordless (I mean a "real" cordless) to tighten screws on standard grade switches with out breaking them, you've got one up on me!
In that dept. I have this screw holder tip thing that slides down over the screw and keeps it on the tip. That is a must for anyone that works off an Extension ladder and often has to reach over to screw in something. That thing is Great!
#575 02/10/01 01:50 PM
Tom Offline
Bill,
I have a Dewalt drill & a clutch setting of 3 on the high speed works for me. I use Hubbell CR series receptacles & CS series switches. These devices are made with a plastic that is not real brittle like some other manufacturers use. The receps run about $1 each when purchased by the case.
By "real" do you mean the type of cordless drill that doesn't use batteries but has a hand crank?
[This message has been edited by Tom (edited 02-10-2001).]
#576 02/10/01 03:24 PM
Tom,
No, I meant "real" as opposed to the light duty cordless screwdrivers that many people seem to buy. [Linked Image] Those things are quite useless except for putting the covers on.
I have a Dewalt myself too. When using standard grade switches they seem to crack whenever I tried using my cordless. I guess that's a good reason to buy spec grade stuff.
#577 02/10/01 09:02 PM
Hey, gotta pound those ground rods right? , well if your aim is as bad as mine, you probably have a few broken off sledgehammer heads .
Figure it out yet?? [Linked Image]
Weld them on a 4' pipe, and you've got a sliding hammer.
#578 02/10/01 11:53 PM
Sparky,
Sounds good for the first 4 feet, how does the last 4 feet go in?
#579 02/11/01 12:58 AM
Bill,
I guess one of my favorites is a cable stripper made by Ideal that strips the outer insulation from circular rubber cable. I worked on a a production line at one time that was having all of the cables to its limit switches renewed, the stripper cut the job in half. It has a guide that holds the cable against an adjustable blade, once the depth is set away you go.
Jeff
PS what about the worst tool you ever bought.
I have several in mind and they all have one thing in common..........they were cheap.
