260
20
Well I just bent a bunch of 1-1/4 today with a hand bender, offsets and 90's. I must say that it is a real feeling of satisfaction when pipe that big comes out looking so good with a hand bender. However I also must say I am beat. That was a real workout, even tho I am 6'3" and weigh 236 lbs.
Do many of you bend 1-1/4 by hand? If so, any tricks or suggestions? I don't do enough big pipe work to warrant a hydraulic, maybe someday.
Sorry, don't have any tricks to offer but can you rent a bender for jobs like that? Benders can't rent for that much I wouldn't think.
When I use a 1 1/4 emt hand bender I put the tail of the piece against a wall and get the whole thing up close and parallel to a wall so I can keep my balance. And I still have to wear all my tools to have enough weight to do a proper job. I really try to avoid the whole thing.
Posts: 5,445 Likes: 2
Here I will speak of the unspeakable, and suggest non-approved methods, in violation of the manufacturers' instructions!
I have had great success bending 1 1/4 and 1 1/2 EMT with the $75 "hydraulic pipe bender" sold by Harbor Freight. This device is little more than a frame with a bottle jack inside. The instructions make it plain that it is NOT for bending electrical conduit. Lets see...$$$$$$$$ for Greenlee, or $75 for HF.....I think I'll try HF anyway.
The "secret" is to limit this thing to very small bends....even a 15 degree bend is best done in multiple steps, moving the pipe a little each time. Thus, you are able to make nice, gentle offsets and saddles. For the right angle bends, store-bought sweeps are the answer. Don't even dream of exceeding a 20 degree bend! The shoe provided for 2" is way over size for EMT, and my experience with it has been very poor.
Greg, They also said to eat all your lunch first so you will weigh more!
[This message has been edited by BigB (edited 10-18-2005).]
As President and chief executive secretary of the Intergalactic Oganization Opposed to 1 1/4" EMT, I should be entitled to a few comments. Bravo to you for your success but I should point out that not all electricians are "6'3" and weigh 236 lbs". The evil abomination 1 1/4" EMT lies is a no-man's land between what is hand bendable [1"] and what is plainly not [1 1/2"]. Since hand benders are made for this size [purchased by the electrician employee], the EC owner doesn't bother to buy a mechanical bender with a shoe of this size. If you need a larger size tube than 1", then why not use 1 1/2"? ~Peter note: our organiztion has been rather sucessful: have you seen any 3 1/2" EMT or its fittings at Home Depot lately?
I have never had enough ass behind me to bend 1-14 with a hand bend unless I segment bend it with a rigid hickey. even then it never comes out the way I'd like.
I asked my foreman what that huge *ss bender in his truck was once...
He replied "It's an inch and a quarter hand bender... although nowdays I mostly use it to scare the sheetrockers who fill our boxes full of mud!"
... Weighing in at a buck-80,and the upper body strength of 10 rats,.. if I need to bend anything over 1",I go for the pre-fab bends...I'm not shy....I'm just lazy... Russ
1.25" hand benders are uneconomic for standard bends.
I use mine strictly for kicks and offsets -- and small ones at that.
I regard it as a two man tool: one heavy dude to apply pressure at the bend; the other to hump the bar.
A solo bend looks like an OSHA violation, to me.
Tesla
