I use gutters like this a lot! And yep <30 conductors at any cross section. If I have a lot of room to work with, I'll take a 6' and put it above or below the panel, with about 2' either side, so I dont have to figure out how to squeeze all the romex, or MC into one stud bay. This work fantastic for MM w/ dist 200a panels with a 3" concentric, and a few halfs at the bottom. Otherwise how would they all fit in there? This way you leave all the grounds in the gutter. (I like cans too)
I put a ground bar, and bond with a #6, only 'cause I never use #8, and have tons of 6 on the truck.
Anyway, while on the subject of derating, and using fewr KO's...
I have seen alot of this done lately.
42 circ panel with 4 1" emt's to cans and gutters (like 50' away) with the whole panel going through it all in #10's, all derated. Late one I saw, I did the math, and it was all pretty close... I don't like it, but seems to be a growing trend with a few companies around here. I guess it saves some mat's and labor on bending a few more conduits, but just don't feel right?
