Page 1 of 4 1 2 3 4
#56978 10/03/05 09:46 PM
Hi All,
Yep, me again with another meter question.
I went down to a couple local electrical supply stores today and annoyed the salesmen (real nice guys) [Linked Image] about their amp-clamp multi-meters.
I looked at a few different meters and the ones that impressed me where the fluke t5 and the Ideal 61-732. A few people on here suggested that I buy the fluke t5 and get a bigger amp clamp type meter later.
Does anyone have any experience with the Ideal 61-732? I was looking at it for my second meter. I will be doing residential and commercial work and the amp clamp on the fluke 330 series meters look like they would be hard to get into a standard service panel.
Sorry if this is a reduntant question. I just don't want to spend my money on something I'll have to replace in a month.
Thanks,
Sam
Samuel A Mercure
#56979 10/03/05 10:26 PM
I have an Ideal DMM with clamp-on ammeter that i think is the same model as yours. While the clamp-on is the least-used feature on mine, I have had occasion to use in a panel and had no problem with the fit. In all ways i love this meter.
#56980 10/04/05 07:50 AM
wv-wire-wrangler you left this part of your profile blank, Occupation:
Where are you in this trade?
Are you a student?
Been the trade thirty years yet?
Based on the answer to the questions above I would make my decision
Mike
#56981 10/04/05 11:20 AM
Hi JW,
Sorry about that, I didn't really know what to put under occupation.
I am a student. I finished my apprenticship class and passed my test, now taking another for the journeymen. The journeymen test is in november then I will probably go to work after the first of the year in residental and commercial.
Sam
Samuel A Mercure
#56982 10/04/05 11:21 AM
The Fluke T5 is OK, but has its limitations. It only reads up to 100 amps and the resistance max is 1000 ohms. (if you're going to get one then get the T6 as it is good for 1000V.)
I carry the T6 on my toolbelt instead of a Wiggey now but have a Fluke 87 in my big toolbox if things get complicated.
By the way, don't get rid of your Wiggey-type testers. Sometimes the fancy digital meters lie to you when testing things like PLC input or output modules.
#56983 10/04/05 12:29 PM
I still prefer the "wiggie" style on my pouch. (Knopp is my favorite). There is no on/off switch to toggle. It shakes in my hand when live voltage is contacted. I do not normally work on circuits above 600 volts. There is less room for human error, such as forgetting to turn on the switch when reading for voltages. But I have a fluke t-5 close by for more accurate readings.
#56984 10/04/05 01:23 PM
Z
Zog Offline
Throw out that wiggy, it is not CAT III rated.
MV/HV Testing Specialist, "BKRMAN"
#56985 10/04/05 01:45 PM
Zog, I just looked at theSq d tester,....the original "Wiggy" , and that thing is still rated for 600V AC operation ....still not protected to 1000V,
I wonder why?
[This message has been edited by togol (edited 10-04-2005).]
#56986 10/04/05 04:24 PM
I don't understand, my wiggy is cat III rated. At least that's what the package said.
It's the Ideal vol-con XL.
Samuel A Mercure
#56987 10/04/05 06:51 PM
Last week I had a chance to check my T5-1000 with a high ccrrent test set and found the ammeter not to be verry accurate. I want to look at again I will post my findings at a later date . One must also remember one or two is not a verry good sample but it will give you something to think about.
Page 1 of 4 1 2 3 4
