by NORCAL - 03/19/24 05:11 PM
1 members (CoolWill), 250 guests, and 13 robots.
#5688 12/01/01 10:40 PM
Nevin Offline OP
What is your preferred way of hanging 1/2" emt? I have an area above a ceiling (wooden trusses with drywall ceiling) in a mfg. plant where I need to run quite a bit of 1/2" emt. It is a bear of a place to work in and I am looking for an approved way of fastening the emt without spending a lot of time and effort. Is there some kind of hanger available that can I can fasten into place and then come along and just snap the emt into it? without having to put a bolt thru? My local supplier is not aware of such an item. I know I've seen something like it in an old installation several years ago. Perhaps my best bet would be to simply use regular 1/2" conduit straps.
#5689 12/01/01 10:57 PM
For wooden trusses......1 hole straps. TS-101 or equiv. fast, easy, and cheap.
#5690 12/02/01 12:30 AM
F
Check out Arlington's "Quick Latch" at www.aifittings.com
#5691 12/02/01 08:36 AM
#5692 12/02/01 06:52 PM
Electure,
Do these have a latch to close or you just push the conduit in and that's it? I've used the first type on that page but not this one.
[Linked Image from erico.com]
[This message has been edited by Bill Addiss (edited 12-02-2001).]
#5693 12/02/01 07:02 PM
You just snap the pipe in and it holds it.
#5694 12/02/01 07:20 PM
Lord help you if you get your finger caught [Linked Image]
#5695 12/02/01 07:47 PM
These work great if the buildingis wood framed.
[Linked Image from aifittings.com]
[This message has been edited by Nick (edited 12-02-2001).]
