1 members (Scott35), 565 guests, and 35 robots.
#56629 09/27/05 01:48 AM
Its not in the code, unless we consider that the code requires us to install equipment acording to manufactures requirements. Most fans for residential use (Hunter, Hampton Bay, Emerson, Concord, ) to name a few, stipulate a minimum of 7'- 0" from the blade to the finish floor. I do not have a code book handy, but will try to get the specific code for this tommorow.
#56630 09/27/05 02:02 AM
See 110.3(B)
#56631 09/28/05 02:01 PM
There is no code requirement regarding ceiling fans. Many homes have 7ft6in ceiling heights so it's impossible to mount a ceiling fan higher than that. Consider that most units hang approx 9in from the ceiling to the bottom of the blade meaning the blades are 81" from the floor.
#56632 09/28/05 02:31 PM
I checked in the IRC and only find refrences for min clearances in pool areas...
Mike Wescoatt
#56633 09/28/05 03:07 PM
My old (1996) copy of the BOCA code states (words to the effect of) no part of the ceiling, including fixtures attached thereto, shall be less than 7 feet from the floor.
If you have a newer copy check section 1200-1207.
