Tom,
You try to balance ceiling fans?
(No wonder you hate them so much) I don't see how the wobble of a ceiling fan is the responsibility of the electrician. As long as it is securely mounted and correctly wired according to code our responsibility should end. Any wobble that may be present is a side-effect of the manufacturing/assembly process. I've never had great success with attempts at balancing and have stopped trying a long time ago.
We don't progam the VCR, We just provide the outlet.
I've seen problems with all brands of Motion Sensors, some big, some small. The new owner should know how to adjust these things themselves. I do not want any callbacks to make minor adjustments or be responsible if it doesn't come on, doesn't shut off, etc, etc, etc.
[This message has been edited by Bill Addiss (edited 11-27-2001).]
