MVP is it possible that the issue with the conduit you describe had to do with having separate phases in each conduit.
I doubt the term "Eddy Currents" would have come up if the problem was strictly a length issue.
You can melt conduits if you have each phase in a different raceway even if the length is exactly the same.
