#5505 11/22/01 07:52 PM
pauluk Offline OP
Which type of light switches do you prefer: Traditional-style toggles or rockers?
My preference is for toggles. The British ones were a slightly different style to most U.S. types, but unfortunately standard wall switches are now available only as rockers. The only toggles still on sale are expensive "retro" mock-Edwardian/Georgian brass types.
[This message has been edited by pauluk (edited 11-22-2001).]
#5506 11/23/01 08:14 AM
Paul,
Over here the toggle is considered to be a standard switch, while the rocker is a "decorator" switch. Most people would stand on their heads to operate the "deco" switch if it was necessary, just so they could have the "fanciness" of it.
Personally, I don't give a rat's ***, they both work just fine!
(I thought the old controversy in the UK was between the "Mods" & the "Rockers") [Linked Image]
#5507 11/23/01 09:30 PM
pauluk Offline OP
Yeah, I've seen all the "Decora" style fittings in the Graybar catalog. I guess that most jobs using the big rocker switches also go for the flat duplex recepts. instead of the normal duplexes with two hole cover plate, right?
