Average pipe job for my shop is ~4000'+.
Like I said, I have had them, and experimented with them only. Don't really use it, but wondered if others did. I have several other methods for the same effect, which are habitual by nature at this point. Can do most by eye better than with anything else just siteing down the side of the first bend. For more complicated, matching, or rolling bends I also use the line method.
Dnk.... "Something you can put pipe in and it will draw a line on one side of two sides of the pipe?" You only need one once you get some good notches on the bender.
(I have attempted to draw what I mean by
notches )
good chalk-line, not the ones that snaps a 1/4" wide fuzzy line with too much chalk.
Or, pencil/sharpie... Find the top of the conduit with the point, lock up your hand with a knuckle on the side, and side the point down the length of pipe you need to bend and a few inches more in both directions. Works really well with some practice.
The "silver stick" stuff is totaly unreliable. Often see the line go all the way around the conduit, what good is that?
Anyway, i too have often thoght about something to simplify drawing that line in the field.... Maybe it's time to invent one?
Reno... "Funny thing about bending pipe....the best "aids" seem to be part of the the job site!"
Oh, sooo true..., unless what ever it is isn't square.
