1 members (ale348),
302
14
For all electrical power engener can visit new web site for electrical substation , tensformer, switchgear and protection at address http://www.sayedsaad.com
this site is all good technical info. Alan
PS Guys check out the site! There's 3 pylons skipping for a start!
[This message has been edited by Webmaster (edited 07-27-2005).]
Sayed, Welcome to ECN!, Yes, this site is well worth a good look to anyone with Power Engineering or HV Systems in mind. Thanks for the link!. [This message has been edited by Webmaster (edited 07-27-2005).]
Sayedsaad, a very informative and good site, i fully reccomend it for anyone who wishes a bit more information on power transfer and control.
Britspark
Posts: 3,682 Likes: 3
Administrator Member
(some unrelated comments removed to get back on topic - sorry for the disruption)
Ok this is darn cool...
Welcome and Thank You! Great Information!
Guys, Having had the chance to sit down and have a good look at the offered material, this is a site worthy of being linked through here. Even the Transformer basics are very easy to understand. Wish I'd had something like this during my training as a Line Mechanic.
I had never heard of using a gas detector to detect faults on transformer. He must be using it to detect long-term events, such as arcing inside the tap changer of the transformer transformer. I would think a high speed differential relay would be a better choice to protect a transformer from internal fault current events. I used to run the oil analysis program for about 100 transformers in a pulp and paper mill. One thing we always took action on was a transformer that was wet, ie had a hydrogen present in that 200 ppm range. I saw several units that failed above that range. Good info, I want to look it over some more when I have time.
GcEE, You would also have to think of the Hysteresis current of that relay coil upsetting the response time, as in a slight delay. It's a good call on the Gas Detector.
