You're right, sorry for the confusion as I haven't even seen the job site yet. Of course with Gfci's fed from a sub-panel the run would be a feeder. I'll see exactly what the customer wants first and then explain the options. If I install a sub for the gfci's, I'll definitely drive a rod, if I install only a pedestal with a rec. for the trailer to save money, being that there will probably be receptacles on the outside of trailer that are gfci protected I will verify the grounding requirements with the local inspector. I realize the trailer has it's own panel technically making the run a feeder if hard wired, but I wasn't certain being that it is cord connected. Depends on exactly what this customer wants besides the 30 a receptacle installed on the pedestal. I'll find out today.
