by NORCAL - 03/19/24 05:11 PM
1 members (Scott35), 268 guests, and 13 robots.
#54272 07/23/05 01:47 PM
Curious if anybody out there has had an issue with gophers chewing on UF cable. We ran power to a clients tool shed in UF but they seemed to think that we should have used GRC because of their gopher situation. I told them I had never heard of such a thing but I have evidence of hungry rats.
#54273 07/23/05 07:31 PM
GRC = Gopher-Rat Cable?
Larry Fine
Fine Electric Co.
fineelectricco.com
#54274 07/23/05 07:33 PM
GRC = Gnawing-Rodent Cable?
Larry Fine
Fine Electric Co.
fineelectricco.com
#54275 07/23/05 09:36 PM
Seems like they should have told you beforehand of their rodent problem, I've never seen this either, UF is tough stuff.
#54276 07/24/05 12:18 AM
There is a large gopher population in my area. I have never come across or heard of a situation where there has been an issue with gophers chewing on UF cable.
#54277 07/24/05 10:17 AM
This is extremely common in my area.
We do a lot of repair work on underground wiring. Most damage can be attributed to either lightning or rodents.
Most of the critter damage happens in agricultural fields where the wire is used for irrigation systems.
GRC seems to be overkill, rigid pvc will work fine, is cheaper and actually better for underground since it won't corrode.
#54278 07/25/05 12:29 AM
I have encountered this problem also. There is also an insect here they call a "Piss Ant" that eats this cabel too. They also like old (direct burial alum)trailer park wireing.
Rob
