1 members (Scott35), 110 guests, and 9 robots.
#53456 06/26/05 06:57 AM
sccat Offline OP
What's the difference between electrical drafter,electrical engineer and electrician?
#53457 06/26/05 07:51 AM
About $50K a year [Linked Image]
Actually, EE designs, drafter draws, electrician installs and repairs.
#53458 06/26/05 07:59 AM
LOL [Linked Image]
I was thinking a lot of things, none of which where appropriate for a nice clean forum such as this. [Linked Image]
#53459 06/26/05 01:21 PM
I was thinking the first draws pretty pictures, the second doodles, and the third makes it work.
#53460 06/26/05 01:54 PM
LK Offline
The engineer thinks he has it right, the drafter, fixes most of the engineers mistakes, and the electrician fixes the engineers and drafters mistakes.
#53461 06/26/05 01:57 PM
We all come together to make a well oiled efficient machine. (Practicing my politician skills)
Roger
#53462 06/26/05 02:13 PM
LK Offline
Roger,
Yes, that is what the result should be, when there is good communications, on the project.
#53463 06/26/05 02:59 PM
Guess who makes the light turn on at the end of the day. [Linked Image]
Edward
Thanks
Edward
#53464 06/26/05 04:14 PM
A draftsman knows what symbol is used for a GFI.
An electrician knows how to install a GFI.
An engineer knows that an op-amp is used in a voltage amplifier arrangement to remove clamping current from the miniature contactor when the toroid sensing coil detects a net magnetic field due to unbalanced current flow to make a GFI work. But proably couldn't pick out a picture of one in a lineup.
#53465 06/26/05 07:52 PM
If all three of them were to do service changes, the one alive at the end of the day would be the electrician.
