#52866 06/09/05 10:08 PM
bot540 Offline OP
Is there a code that prohibits a gfi with in a certain distance from a lake? I'm asumming it's 10 feet like a pool.
Jesus may have been a capenter,but God was an electrician.Genesis1:3
#52867 06/09/05 11:15 PM
Nope, you can have a receptacle on a pier over the lake. Same with salt water.
#52868 06/10/05 01:29 PM
If the installation is near a body of water as stated check article 555 to determine elevations from the water datum plane if applicable 555.19 ect.
Charlie
#52869 06/10/05 02:01 PM
note 555.1 says "Private, noncommercial docking facilities constructed or occupied for the use of the owner or residents of the associated single-family dwelling are not covered by this article."
You should still be aware of the artice though so you can make good "design" decisions.
#52870 06/10/05 07:08 PM
See 682.15 in the 2005 NEC
