Long-Time hacksaw user, 1st year Sawzall user (except for larger sized Conduits - always used Sawzall for these).
Having the Cordless Sawzall now (Milwaukee type - 18 VDC cordless w/ 2.4 Ah Battery Packs) has altered my cutting protocols and beliefs so dramatically, I have contemplated placing the Hacksaws in Dumpsters for Permanent logistical storage!
(Translation: Toss the Hacksaws in the trash!).
Portable Bandsaw and Side Grinder have also been Long-Time used tools, when cutting conduit sizes of 1½" and up.
Definitely for Unistrut cuts.
***BTW, Milwaukee is introducing a Cordless Portable Bandsaw - using the 24 VDC, 3.0 Ah Battery.
***As to cuts on Conduits of ½" to 1", having the Conduit secure is the key to achieve repetitive successful "close-to 90°" square cut results.
Secure it by either:
<OL TYPE=A>
[*] Clamp the Conduit down to your Materials Cart (or other commonly used device),
[*] Hold Conduit down with your Foot - usually by setting it on top of a Board,
[*] Stabilize the Conduit by "Bridging" it with your legs (wedged between the back of one knee, squat down so it is on top of the other leg) - have done this for many years and still results in the most stable, simple, readily available and successful technique,
[*] Having an "Assistant Cutting Technician" hold the Conduit.
</OL>
A slight variance off true 90° cut should not cause any problems.
When it comes to angles of 60° and less, along with Conduit not fully seated into a fitting - or both together, then I could say we have an addressable issue! (or two!)
These may result in:
- Fish Tape leader getting wedged into the void spot(s), making it really difficult to push in the Tape,
- Insulation getting damaged while pulled in through a point of exertion - mainly on a Coupling area in close proximity of back-to-back 90°s, or 90°-offset/kicks,
- Allow Water to enter the Conduit.
My 2¢
Scott35
