1 members (Scott35), 403 guests, and 13 robots.
Coastal Offline OP
Pardon me if this seems like a stupid question but is there any danger of damaging a commercial dishwasher whose nomenclature reads 1 phase 208 volts by supplying it with 240 volts???
That's more than 15% over the rated voltage.
That's nominal voltage as well -- If the 240V supply is running near the upper end of its allowable tolerance then it will be even more.
Would it be possible to install a transformer to buck the voltage down a little?
Coastal Offline OP
It would be possible but I don't know how practical. I'm not familiar with this type of equipment. Would it fit behind the dishwasher? Do you know of a company I could contact about such a "step down" transformer?
Try this link--
http://www.sola-hevi-duty.com/products/transformers/BuckBoost/
Then read this--
https://www.electrical-contractor.net/ubb/Forum2/HTML/001921.html
[This message has been edited by Redsy (edited 03-08-2005).]
