aldav53 Offline OP
What type of dimmer is used to control a transformer for low voltage lighting? Would a fluorescent dimmer work?
You have to know what kind of transformer it.
magnetic or electronic. the dimmer must specify if it is for electronic transforer or magnetic.
you also have o realize that some dimmers require a neutral connection to the dimmer otherwise it will not work.
edward
Thanks
Edward
Some low voltage transformers can be dimmed with regular dimmers. WAC makes them for their under-cabinet puck lights. Many will not work with standard dimmers though, so read any literature that comes with the transformer. Like Edward said, you need to know if it is a magnetic or electronic transformer.
Pat
Power to the people
A possible (if costly) option for dimming LV lighting with a conventional magnetic transformer is to run the transformer primary from a variac (variable autotransformer).
aldav53 Offline OP
The dimmer is for a magnetic transformer, and I believe the transformer is too, I'll have to check.
Thanks,
