235
27
Iam wiring 5 apartment units, each unit having 60 amp panel, what is the the total service that I will need to have. wire size? amps size , thanks
With the limited info given it would have to be 300 amps.
However I would bet that is way oversize.
The only way to give an accurate answer to this question would be to know the total calculated load.
Bob
Richard, use article 220 to figure this out for yourself, then post you figures here.
Roger
With a question like that you wouldn't be wiring my apartment building.
My point is this: Everyone has their limitations. An electrician who has done commercial work for their whole career might be baffled by residential. Likewise, someone who only wires homes will probably have a hard time with a motor starter.
Peter D.
[This message has been edited by CTwireman (edited 01-19-2005).]
Peter
Isn't this the same question you asked under your post "amps"? Its hard to believe you would be installing only a 60 amp panel. I would think the min would be 100 amps.
[This message has been edited by Bob (edited 01-19-2005).]
230.79(C) restricts the minimum rating of 100 amps for each dwelling.
With an AC load of 40 amps for each unit, I'd say 400amp to 600amp depending on sq ft of each.
You need a public meter for general areas.
shortcircuit
Shortcircuit, the 100 amp mininmum would only apply to a One-Family Dwellingsee definition of Dwelling, One-Family in article 100.
Richard, why don't you attempt to do the math and let us see what you come up with?
Peter has a good point, this seems to be out of your expertise.
Roger
[This message has been edited by Roger (edited 01-19-2005).]
Your correct Roger...I only looked at the definition of Dwelling Unit shortcircuit
