by ale348 - 03/29/24 01:09 AM
by NORCAL - 03/19/24 05:11 PM
#47107 01/09/05 01:57 PM
cka123 Offline OP
Hi everyone.
I was replacing an old light switch with knob and tube wiring. After removing the switch I checked the voltage with my meter between the 2 switch wires and I get 120 volt reading yet when I connect them together they make the light work. Can anyone explain what's going on?
Thanks.
#47108 01/09/05 02:20 PM
Sounds normal to me.
The meter is in series with the light bulb.
#47109 01/09/05 02:41 PM
Cka
When you are touching the prods of your tester to the two conductors you are in essence completing the circuit. The circuit is a 120 volt circuit, so your tester will read 120 volts.
Pierre
Pierre Belarge
#47110 01/09/05 02:50 PM
cka123 Offline OP
Thanks guys. I guess if I removed the light bulb I would not get 120v reading on my meter.
Appreciate your response.
