278
16
My jw test is coming up soon, I need help studying. So give me all you got.
Here's one from a quiz I give my students. BTW ... it's a trick question:
The service drop attaches to the house above the second story window and the meter is 5' from the ground. You only have 9" between the window and the corner of the building. Is this sufficient clearance to run the SEC down to the meter? If not, how much do I need?
What is longer, a stick of 1/2" EMT or a strick of 1" Gal?
Anonymous
Unregistered
When can a white conductor be used as a hot conductor and if done how must it be identified? Code article please.
Steve,
Does the window open or is it plate glass that stays shut?
Does a cross-eyed dyslexic read normally?
?yllamron daer cixelsyd deye-ssorc a seoD
Ryan Jackson, Salt Lake City
Why does it hurt when I....
Never mind.
200.7 (c)(3) reidentified as white. on the supply side of the switch.
sorry I meant to indicate it use. not white.
