0 members (), 373 guests, and 12 robots.
#46335 12/19/04 03:45 PM
Roger
I understood the angle your question was coming from [Linked Image]
As we have seen, it is good to stir the pot once and awhile...Since Bennie's passing, you and Bob have picked it up [Linked Image]
Pierre
Pierre Belarge
#46336 12/19/04 06:32 PM
PaulUK posted a method he used a while back and I'll see if I can find it, if I can't, maybe he'll see this and post it again.
I can't find the original thread with a quick search either, but the following document includes a section on the method I described and goes into more detail:
http://www.tradeport.on.ca/ApplicationNotes/aemc.pdf
#46337 12/20/04 10:09 AM
Tom Offline
Trekkie,
Yup, I do think some of the numbers are arbitrary.
Does the 10 foot tap rule offer that much more safety over what could easily be the 11 foot tap rule? :-)
I've also heard the tale that the 6' 7" mounting height for a disconnect handle was based on what the shortest person on the code panel could comfortably reach.
Frequently, when I see a number in the NEC, I wonder what the reasoning was that resulted in that exact number. I suspect that at least a few of them were selected because they were easy to remember.
