0 members (), 373 guests, and 12 robots.
#46282 12/18/04 10:13 AM
I have a question, how would you guys wire a regular three section traffic signal? The lights have a terminal block in the yellow section that I would like to keep, considerng that all wiring from the block to the light sockets is aluminum. If you say four-conductor cable, tell me where to find it besides online and PENNDOT's office. None of the lights are permanent. Diagrams would be helpful, but not necessary.
Thanks,
Ian
(Theelectrikid)
[This message has been edited by Theelectrikid (edited 12-18-2004).]
#46283 12/18/04 10:50 AM
The wiring to the sockets is probably tin plated copper mot aluninum. Traffic signal cable is manufactured to IMSA standards and for a 3 section head you would a cable with a RED for red ball YELLOW for yellow ball GREEN for green ball. WHITE for common if there is an green arrow for left turn it would be on a BLACK.At this time i cannot remember what color a yellow left turn arrow is fed with. remember that in the wiring going io the signal head that green is power to the green ball (indication) NOT GROUND.
#46284 12/18/04 10:55 AM
To buy signal cable try Clifford of Vermont
#46285 12/18/04 11:49 AM
I have a newer LED Traffic siginal with a Brown wire fir the Hot to the green. It has a 4 postiion terminal block wire order red yellow brown and the neutrals all under the last screw that then goes to my sequecer a T3 from lights to go .com and that goes to a 3 wire orange cord
[IMG]http://upload.pifiu.com/uploads/2004-dec/t3.jpg
[This message has been edited by ComputerWizKid (edited 12-18-2004).]
Theres always enough room in the junction box.You just need a bigger hammer
#46286 12/18/04 06:35 PM
 (oops)
[This message has been edited by Bjarney (edited 12-18-2004).]
#46287 12/24/04 10:48 PM
Okay, thanks for the help so far guys.
But, how would you wire one with three single-pole toggle switches, and some 14AWG Stranded red, blue, black, white, and green wire?
